Discussion topic: Keep losing WiFi
This message was authored by: Mazza11
Keep losing WiFi
Wi fi keeps going off and on . More off than on
Re: Keep losing WiFi
@Mazza11
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
This message was authored by: Foxtail_
Same in here. Had sky installed last week and on the first evening WIFI dropped and all deviced got disconnected. And since then it keeps doing that multiple times a day. I've lost count how many times I've restarted or factory resetted the router... And every time it drops the WIFI devices do not re-connect.
