Discussion topic: Issues
This message was authored by: andy+mullen
Issues
Phoned a short time ago to report nine times today WiFi was down.  Told to reset, which I did, then it's back to dropping out.  There's defo an issue
Re: Issues
@andy+mullen
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
