Discussion topic: Issues
This message was authored by: Jacquil
Issues
Every day I lose connection to WiFi. I work from home for NHS critical service. I need this sorted
Re: Issues
@Jacquil that you use your line that is sold for domestic use to deliver a "critical service" is your decision but it does not get you any priority so you need to have a back-up-up plan. This isnt Sky being difficult it is a fact of life that many people working from home fail to realise that it usually takes several days to fix faults on domestic lines.
If the issue is your hub loosing connection to the exchange call Sky as line drops can indicate a fault. Whether they can get Openreach to check the line depends on how frequently  the drops are and whether there are other faults.
