Discussion topic: Issues with line and broadband
This message was authored by: robertgiles
please contact me wdsday afternoon has my landline is down has well has broadbrand robert thank  by mobil number
Re: Issues with line and broadband
@robertgiles The Forum is NOT sky Customer Service, you will have to call sky, and you will not get any call back from posting as you have requested!
@robertgiles
No one will / can phone you anyway. Your Community tag name isn't linked to any Sky accounts you have so no one knows who you are. You will need to initiate contact.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
