Discussion topic: Issues with completing boardband order
Message posted on 18 Dec 2025 06:40 PM
Hello,
I'm Tochi Ogbonnaya.
I got a test few minutes ago about an issue with completing my order of a broadband.
please see the message below
'Hi. Sorry but there's an issue with completing your Broadband and Talk order. To get up and running, just give us a call on xxxx'
Best Wishes
Tochi
Message posted on 18 Dec 2025 06:46 PM
Re: Issues with completing boardband order
@Tobescokalux
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
So did you contact Sky?
Message posted on 18 Dec 2025 06:49 PM
No options to speak with a rep
Message posted on 18 Dec 2025 06:51 PM
@Tobescokalux
These are the current methods for contacting Sky, and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
