Discussion topic: Issues with accessing to work VPN
Message posted on 21 Nov 2024 06:32 PM
How do I get MAP-T disabled on my broadband as I am unable to connect to work VPN due to this being enabled and I need access to work networks whilst at home. I have a white sky max hub - home hub 6
Message posted on 21 Nov 2024 06:43 PM
Re: Issues with accessing to work VPN
You would need to contact Sky and request that MAP-T is removed.
Before that you could try enabling uPNP in the router GUI. Open a browser and type 192.168.0.1.
user is admin and the password is the WiFi password labeled on the router.
Click on advanced then device discovery and you should find the uPNP option.
If it still doesn't work then you can disable it again and call in.
