2
This discussion topic has been answered Discussion topic: Issues w
This message was authored by: Sx61bex
Issues w
Problems with my broadband not coming on lights either flashing orange or no light at all so have had no WiFi since lunchtime, its been switched off re started and reset on the back of the box numerous times with no avail. Do have an alarm system for mental health which this issue is effecting
Re: Issues w
@Sx61bex
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Issues w
@Sx61bex
Avatar for Sx61bex
Re: Issues w
Thank you I tried everything but it happened to be a fault outside my property which needed an engineer, the engineer came at 9am the next morning and fixed the issue. Appreciate your advice thank you.
