Discussion topic: Issue with Sky Broadband Connection Dropping Out Early Every Morning
This message was authored by: daniel5861
Hi,
my broadband connection drops out overnight, 90% of the days, for the last month or two.
I normally wake up at 6/6.30ish and most days no internet available. Will sometimes be up 1/2am and never any issues at that time, so must be happening sometime early am.
Always the lights on router all show fine, but no devices (tablet, phones, pc, google hub, Phillips Hue hub, sky+ box) are able to connect.
Most often tablet can still detect the network but when try to reconnect just get an unable to connect message. However, sometimes the network isn't detectable. On the odd occasion will reconnect for a few seconds, load a webpage, and then drop out again, three/four times, before going into one of the two previously mentioned states (unable to connect or undetectable).
This resolves when reset router, but then same thing happens the next day so very frustrating.
Have seen people get asked for stats so here's what my router is saying following reset about 30 minutes ago.
Router Statistics
System Up Time: 00:32:35
Port    Status  TxPkts     RxPkts      Collision Pkts    Tx b/s         Rx b/s       Up Time
WAN   MER       75979      1629 63.   0                            40811         37942       00:30:57
LAN     Up          5527         1134           0                            13486        720            00:32:35
WLAN Up          2003 21   96007     0                             4332 62    68840      00:31:40
Broadband Link                            Downstream                                         Upstream
Connection Speed (Kbps)        79999                                                     19520
Line Attenuation (dB)                DS1:12.6    DS2:29.4    DS3:44.1      US0:4.3    US1:22.9    US2:33.9
Noise Margin (dB).                        DS1:3.5    DS2:3.4    DS3:3.5            US0:6.4    US1:6.2    US2:6.1
Any help? Or is it as simple as needing a new router?
Re: Issue with Sky Broadband Connection Dropping Out Early Every Morning
@daniel5861
If you can see if there is a label on your router for the model type or if you know what it is post it back.
Your stat's look good, but i do think you have the SR102 router from viewing them, and it is circa 2014 so maybe 10 yrs old now. The link will also take you so you can view the type
Setting up your Sky hub | Sky Help | Sky.com
Avatar for daniel5861
Thanks, I’m away from home the next couple of days but will post an update when back.  That sounds about right date wise though
This message was authored by: mae-3
@daniel5861
Recommend you upgrade to a dual-band 2.4Ghz & 5Ghz VDSL2 wireless router, eg: @JimM1 is quite correct that is an SR102 Sky Hub router 2.4Ghz only and that needs upgrading to a newer model. You'll need to talk to Sky for an upgrade or search for a commercial router compatible with Sky DHCP Option 61 and VDSL2 system standard for your service.
