Discussion topic: Issue with Broadband
This message was authored by: NR71
There seems to be an issue with my sky wifi box, it says that the broadband is working when running a test via sky website (and the light is up on the box) however, the wifi light isn't on and there is no wifi coming through the house. Please advise on how this can be resolved or please give me a phone number where I can talk to a person and not an automated system as that just runs the test and says the broadband is fine.
Re: Issue with Broadband
@NR71
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Avatar for NR71
I don't have a Sky Talk Landline, am I able to call from my mobile phone?
@NR71
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
Towards the bottom of the link it MAY provide a phone number in a section called ‘Need more help’.
🔶 Sky Assistant should also be available via
for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Avatar for NR71
Please provide a phone number to speak to a human in the customer service team
