Discussion topic: Is there down time on Wi-Fi/broadband during installation? Thanks
This message was authored by Pjh3 This message was authored by: Pjh3
Is there any downtime on Wi-Fi/broadband during installation of gigafast?
Re: Is there down time on Wi-Fi/broadband during installation? Thanks
@Pjh3
There shouldn't be, but there's also no guarantee of continuity of service.
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Pjh3
Thank you for your help
@Pjh3
No problem.
One instance, for example, of really significant down-time is where a fibre installer decides to cut an existing working copper line to use as a pull-through to bring optical cable along a duct which then turns out to be blocked...
@Pjh3 As @TimmyBGood there can be considerable downtime in some circumstances but most switches are seamless. Getting the fibre to my home was a drama which took months but as the copper line followed a different route it remained up until after the new fibre service was up and running. The forum tends to collect horror stories as happy customers dont post very often.
