Discussion topic: Is sky down?
Message posted on 05 Jan 2026 03:23 PM
Is sky down?
Message posted on 05 Jan 2026 03:26 PM
Re: Is sky down?
@Justaddlime36
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 07 Jan 2026 10:17 PM
Re: Is sky down?
Yeah im fully aware I just got on a rant I contacted sky at the same time and as per usual an engineer had to be booked so had to wait in yet again. Im in process of searching for a new provider paying 53.50 for Internet that works 3 months and go off and repeat the same cycle so hopefully ill be fully done with sky in coming months woohoo!
Message posted on 07 Jan 2026 10:28 PM
Re: Is sky down?
@Justaddlime36 No need to wait you can go at anytime, do you happen to know if your fault is always internal or external, same line you may just have the same problem when you move supplier!
