Discussion topic: Iris having WiFi connection issue
This message was authored by: Iris42
Hi I can't connect to the Internet, the Internet light is off, I tried to disconnect n unplug it still isn't working pls help
Re: Iris having WiFi connection issue
@Iris42
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
