Discussion topic: Ipv4 suddenly not working...
This message was authored by: Lucyoyler
Message posted on 16 Jan 2026 05:22 PM
I've troubleshooter as best as I can but I am stuck. My Sky fibre has suddenly stopped 'using' ipv4 and is only connecting (wirelessly and wired) to ipv6? I don't know how else to word it. I've restarted, cycled and reset the Sky box, ticking the ipv6 box connects me to the Internet but nothing loads properly... for example on ipv6 the Steam store page doesn't load, but Google does. My discord wont open but YouTube does.
Message posted on 16 Jan 2026 06:02 PM
Re: Ipv4 suddenly not working...
@Lucyoyler Use the following to see what you get from sky, www.whatismyipaddress.com both should be returned to your sky hub!
This message was authored by: aangelss
Message posted on 16 Jan 2026 08:41 PM
you can turn off the IPv6 on your device and force it to only use IPv4. I had to turn it off on mine cause the sky router keeps restarting the IPv6 service and lease renewal every 30 min and you can't turn it off on their router itself.
