Discussion topic: Internet stops working everyday, some times a hour sometimes more, it’s been going on for months
Message posted on 27 Apr 2024 11:30 PM
Really feel ripped off, been having problems with the internet for months, was talked into having fiber fitted which I did , the signal is stronger but still cuts out most days for an hour or two , I've had enough to be honest, it's not cheap I can hardly afford it as it is , absolute garbage I'll try and call again tomorrow, I've told everyone I know how bad sky is and to not bother with it ,
Message posted on 28 Apr 2024 08:15 AM
Re: Internet stops working everyday, some times a hour sometimes more, it’s been going on for months
@771166 you are not talking to Sky by posting in the forum and frankly threats are pointless as unless you are in the 31 day cooling off period ir are out of the 18 month fixed term period you will be charged cancellation fees if you move. Added to which if it iis a line issue and you move to another isp using the same line guess what the fault comes with you.
If you would like help in getting the issue fixed tge forum can probably help but we are customers like yourself so need some information so startvby posting your hub's stats see Find your Sky Broadband router statistics
