Discussion topic: Internet stopped and orange blinking light on hub
Message posted on 16 Aug 2025 06:46 PM
My internet stopped working halfway through a program, and won't connect again, just orange blinking light on the internet indicator on hub, have tried all the unplugging and run tests but no faults come up .
Message posted on 16 Aug 2025 06:52 PM
Re: Internet stopped and orange blinking light on hub
@D12355
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
