6
Discussion topic: Internet speed getting worse, and now keep dropping out
This message was authored by Jimbogot213 This message was authored by: Jimbogot213
I supposedly have super fast broadband, but average download speed is 5mbps, the speed has been progressively getting worse and is now regularly cutting out.
I cant contact sky for help as I can only find a phone number that's always closed when I'm not at work, and not sure how to rectify the issue?
Anyone have an email address for sky?
This message was authored by Highlinder This message was authored by: Highlinder Answer
Re: Internet speed getting worse, and now keep dropping out
@Jimbogot213What does it say when you try to run the broadband test does it say " Can't find your router"?
@Jimbogot213Have you tried running the broadband test to see if it picks up any faults?
Jimbogot213
Hi, thanks for the reply, but unfortunately the test does not work as I have previously upgraded the router, in a hope to rectify the fault. However, its not made any difference. Prior to changing the router, yes I had done the test, but that never came back with a fault.
Jimbogot213
Yes, that's the message I get
@Jimbogot213Are you in the UK or Ireland to enable you to call Sky?
@Jimbogot213 Sky's UK lines open at 7am and close at 10pm and calls are free if you dial 150 on a Sky Talk line. Irish lines are different.
You would be advised to reconnect the Sky hub if calling as Sky's disgnostics need that to work.
