Discussion topic: Internet speed dramatically below what I’m paying for
This message was authored by: Dkryn
Paying for 900mb speeds currently getting 10mb download speeds? What?
Re: Internet speed dramatically below what I’m paying for
@Dkryn run the Service Checker in the My Sky app to check the speed to your hub which is what is guaranteed. If tgst has an issue the app should offer further help.
if as is likely the spedd to the hub is not the issue then the problem is marginal WiFi in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
