Discussion topic: Internet problems
This message was authored by: MrBarclay
Internet problems
The router is not giving Internet connection out of no where, was using it fine then cut out and has done for 30min, everything stopped working.
Re: Internet problems
@MrBarclay
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
