1
This discussion topic has been answered Discussion topic: Internet problems
This message was authored by: Angiemadison
Internet problems
For the last two days my hub stops working causing the internet to fail I've been home 1 1/2 hours still not working
Re: Internet problems
@Angiemadison
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
@Angiemadison
