Discussion topic: Internet problem
Message posted on 07 Dec 2025 10:58 AM
Internet problem
My Internet box keeps going off. There's something wrong with it. I don't understand. We only get Internet for five minutes and then it goes off again and that's constantly there is a problem
Message posted on 07 Dec 2025 11:32 AM
Re: Internet problem
@Yaz123
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Red light on ONT; See this link ~ https://helpforum.sky.com/t5/Broadband-Talk/Can-t-connect-to-broadband-and-have-a-red-light-on-your-...
