Discussion topic: Internet not working
This message was authored by: Slg1234
Internet just turnt off, still not on tried to reset still haven't worked, new to sky only had for week and this is annoying 😞
Re: Internet not working
@Slg1234
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up of Sky customers helping other Sky customers with additional help from Superusers like myself.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
