Discussion topic: Internet not working
Message posted on 08 Jul 2026 03:55 PM
Internet light flashing so not working
Message posted on 08 Jul 2026 03:56 PM
Re: Internet not working
@Teress
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
