Discussion topic: Internet not working
Message posted on 03 Jul 2026 03:45 PM
Internet not working. Everything plugged in but green internet light on router is off
Message posted on 03 Jul 2026 03:49 PM
Re: Internet not working
@EmilyRutter
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
