Discussion topic: Internet not working
Message posted on 13 Jun 2026 08:32 AM
Message posted on 13 Jun 2026 08:35 AM
Re: Internet not working
Message posted on 13 Jun 2026 10:36 AM
@Christineoneil
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
