Discussion topic: Internet not working
This message was authored by: Ricky12345
My router has a red light on voice but no light on the internet
Re: Internet not working
@Ricky12345
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
