Discussion topic: Internet not working
This message was authored by: Balajimanokaran
My internet is not working, I could see solid red light in openreach device. Tried restarting openreach device and wifi device but still it's not working.
Re: Internet not working
@Balajimanokaran
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
