Discussion topic: Internet not working
Message posted on 01 Mar 2026 01:58 PM
My internet is t working, I've checked the connections and everything seems good. But the internet light on my hub is t on and the voice light is amber.
Message posted on 01 Mar 2026 02:13 PM
Re: Internet not working
@Danjj There is the possibility the orange voice light is an issue disguising the Internet fact, switch the hub off for 5 minutes, then see what it's like when back on!
Message posted on 01 Mar 2026 05:05 PM
This hasn't worked, when trying to connect to the internet I page comes up that there is something wrong with the connection but everything is plugged in
Message posted on 01 Mar 2026 05:08 PM
@Danjj See the other link below.
Try running the line test here to see if any faults are found:
