2
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: Michala1
My Internet isn't working. Middle button is not on at all. I have tried with turning off and on but still won't work.
Can someone come out to fix the issue
Re: Internet not working
@Michala1
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Michala1
@Michala1 Not on a Forum posting like you have done as it is not sky Customer Service, if you need sky then you have to call them direct, 150 from your landline if working is the easiest and from 8am to 8pm....
Service checker is below if you wish to do some testing yourself!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
