Discussion topic: Internet not working
This message was authored by: 12hello1
On our sky router the power and WiFi lights are green however the internet and voice ones are orange. We can't connect to the internet either. Please help
Re: Internet not working
@12hello1
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
