2
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: Vicky159
Our internet is not working at all. We have reset it and ran all tests but it's saying there's nothing wrong but there is
Re: Internet not working
@Vicky159 @AndAston
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
This message was authored by: AndAston
I'm having the same problem
@Vicky159 @AndAston
