1
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: JordD123
Have amber light on router for internet and voice. WiFi notworking
Re: Internet not working
@JordD123
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@JordD123
