Discussion topic: Internet not working
This message was authored by: isinclair
My internet is not working I have two orange lights one flashing
Re: Internet not working
@isinclair
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
@isinclair
See further down about hub lights…
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
