Discussion topic: Internet not working
Message posted on 23 Dec 2025 06:27 PM
Everything is on but the light is flashing green on the router
Message posted on 23 Dec 2025 06:28 PM
Re: Internet not working
@Lucy226
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
