Discussion topic: Internet not working
Message posted on 13 Dec 2025 07:00 PM
My internet has been terrible all day. I'm having to use my phone data as it won't work whilst on WiFi and my sky tv is really slow if it works at all.......AGAIN!
Message posted on 13 Dec 2025 07:06 PM
Re: Internet not working
@J82
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
