Discussion topic: Internet not working
This message was authored by: Lynseynolan
My internet is not working red light appears on box have tried to unplug restart etc not worked
Re: Internet not working
@Lynseynolan
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Lynseynolan
If your ONT shows a red light then have a read of this:
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
