Discussion topic: Internet not working
Message posted on 21 Nov 2025 02:36 PM
My internet isn't working and have tested all the steps to resolve this
Message posted on 21 Nov 2025 02:40 PM
Re: Internet not working
@Kimberly7
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 21 Nov 2025 03:47 PM
@Kimberly7 That does include a call to sky when all else does not get you going, has that been done and if so what were you told?
