Discussion topic: Internet not working
This message was authored by: Seama1
Internet is not working in my home
Re: Internet not working
@Seama1
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
