Discussion topic: Internet not working
This message was authored by: Emma_2
Internet box keeps flashing and not letting us watch sky glass or connect to the internet
Re: Internet not working
@Emma_2
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
