Discussion topic: Internet not working
Message posted on 27 Oct 2025 10:19 AM
Internet is not working I have tried resetting everything and still nothing works
Message posted on 27 Oct 2025 10:21 AM
Re: Internet not working
@Nic144
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
