Discussion topic: Internet not working
This message was authored by: Lokesh+Surekha
My internet is not working and it's frequently disconnecting and it's dead slow. Not working properly since Friday 24th October.
Re: Internet not working
@Lokesh+Surekha
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
