Discussion topic: Internet not working
This message was authored by: JadeSalisbury
Internet stopped working
This message was authored by: peter-marlow+1966
Re: Internet not working
Can please  give  more information about this issue please,  have you  run the broadband service checker  on the sky website, you may have an outage ?
P c marlow
@JadeSalisbury
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
