Discussion topic: Internet not working
Message posted on 07 Oct 2025 08:23 PM
Fix my internet please!
Message posted on 07 Oct 2025 08:26 PM
Re: Internet not working
@Tj80
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
