Discussion topic: Internet not working
This message was authored by: Triggerpoint
Was watching Netflix and internet just stopped working green light going on and off
Re: Internet not working
@Triggerpoint
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
