Discussion topic: Internet not working
Message posted on 15 Sep 2025 11:05 AM
My internet is off
Message posted on 15 Sep 2025 11:16 AM
Re: Internet not working
@Jemma1977
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
