1
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: June1611
No Internet 2green lights on my router and 2 orange light none are flashing
Re: Internet not working
@June1611
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working in the morning and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
@June1611
