Discussion topic: Internet not working
This message was authored by: Chloe2010
My Internet is not working  on my sky box the power light is green the Internet light is intermittently flashing amber WiFi is green and voice is amber. I have reset the device and turned the power off for 20seconds
Re: Internet not working
@Chloe2010 If it has just started doing so then sky may not as yet be aware off any fault's but do run the service checker to see if anything is known as off yet!
