Discussion topic: Internet not working
Message posted on 28 Jun 2025 02:12 AM
The bill is paid, service checker says there's no issue, why is the internet not working on any of my devices?
Message posted on 28 Jun 2025 04:21 AM
Re: Internet not working
When this happens between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
