Discussion topic: Internet not working
Message posted on 21 Jun 2025 07:37 PM
My internet is currently not working and hasn't been all day. I've reset the box and that did not help, I've checked everything online and all day the box is working fine however I can't seem to get internet still
Message posted on 21 Jun 2025 07:39 PM
Re: Internet not working
@Paigecow
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
