Discussion topic: Internet not working
This message was authored by: Sandy491
Internet has stopped working. There's only 3 lights on, on router. I've tried turning the router off & on but it's still not working. I've tried the service checker, it says there's an issue but when it runs the tests it says everything is working but it isn't.
Re: Internet not working
@Sandy491
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
