Discussion topic: Internet not working
This message was authored by: Yvettexxxx
Internet stopped working
Re: Internet not working
@Yvettexxxx
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
